关键词:IGBT EconoPACK 4 可再生能源 UPS 空调
时间:2015-06-09 10:23:39 作者:Infineon 来源:中电网
Infineon公司的EconoPACK™ 4是AC和DC连接隔离的IGBT,电流范围从100A到400A,电压650V和1200V,具有可靠性高,容易安装和高效率等特色,主要用在通用驱动器,伺服驱动, 可再生能源,UPS和空调等.本文介绍了EconoPACK™ 4主要特性,优势,以及评估板F3L2020E12-F-P_EVAL主要特性,电路图,材料清单和PCB设计图.
The EconoPACK™ 4 package perfectly fits into the well-known Econo portfolio. EconoPACK™ 4 features a screw power terminal, providing an excellent electrical connection. The DC and AC links are separated and distinguishable at a glance for ease of use. Control pins feature our PressFIT technology for solderless assembly. A new and highly reliable ultrasonic welding process is used for all connections between the terminals and the DCBs within the module.
Optimized gate driver connection is possible by placing the driver on top of the module. Low parasitic stray inductance and optimized thermal resistance to heat sink support to excellent inverter solutions.
The EconoPACK™ 4 portfolio is available in current ratings from 100 A up to 400 A. 6-pack and half-controlled input rectifier configurations (available in 1600 V with current ratings of 240 A and 360 A) are tailor-made for industrial applications.
分享到:
