[原创] Cypress CCG1 USB和USB电源端口控制解决方案
关键词:ARM Cortex-M0 MCU USB 电源管理 CCG1 USB
时间:2015-04-29 12:46:26       作者:Cypress       来源:中电网
Cypress公司的CCG1是完整的USB Type-C和USB电源端口控制解决方案,可提供100W USB电源功率.器件具有32位MCU子系统,工作频率48MHz,32KB闪存和4KB SRAM,模拟区块包括12位1MSPS ADC,数字区块包括两个可配置的16位TCPWM和一个主或从I2C,主要用在笔记本,平板电脑,监视器和坞站,电源适配器和USBT型电缆.本文介绍了CCG1主要特性,框图,多种应用电路,以及CCG1演示板主要特性,电路图,材料清单和CCG1演示板设计文件.
CCG1 provides a complete USB Type-C and USB Power Delivery port control solution. The scalable and reconfigurable corearchitecture of CCG1 enables a base Type-C solution that can scale to a complete 100-W USB Power Delivery with Alternate Modemux support. CCG1 is also a Type-C cable ID IC for active and passive cables. The ARM® Cortex®-M0 CPU based core can use
common open source firmware or custom solutions developed with common libraries and APIs. CCG1 is the CC controller that detectsconnector insert, plug orientation, and VCONN switching signals. CCG1 makes it easier to add USB Power Delivery to any architecturebecause it provides the control signals to manage external VBUS and VCONN power management solutions as well as external muxcontrols for most single cable-docking solutions. CCG1’s packaging options, and programmability, enables any USB Type-C and USBPower Delivery solution.
Type-C Support..
查看全文
