[原创] Fairchild FSBB30CH60D 3kW三相马达逆变器参考设计
关键词:工业控制 马达控制 家用电器 空调 工业马达 FSBB30CH60D
时间:2015-04-23 09:37:00       作者:Fairchild       来源:中电网
Fairchild公司的FSBB30CH60D是Motion SPM® 3模块,提供交流马达,BLDC和PMSM马达的全特性高性能逆变器输出级.模块集成了内置IGBT优化了的栅极驱动,以降低EMI和损耗,同时提供多种保护特性,包括欠压锁住,过流关断,驱动IC的热监测和故障报告.主要用于家用电器和工业马达驱动.本文介绍了FSBB30CH60D主要特性,框图,典型应用电路,以及3kW/220VAc和30A/600V 3相IGBT逆变器参考计的主要特性和指标,设计框图,电路图和PCB布局图.
FSBB30CH60D is an advanced Motion SPM® 3 module providing a fully-featured, high-performance inverter output stage for AC Induction, BLDC, and PMSM motors. These modules integrate optimized gate drive of the built-in IGBTs to minimize EMI and losses, while also providing multiple on-module protection features including under-voltage lockouts, over-current shutdown, thermal monitoring of drive IC, and fault reporting. The built-in, high-speed HVIC requires only a single supply voltage and translates the incoming logic-level gate inputs to the high-voltage, high-current drive signals required to properly drive the module’s internal IGBTs.
Separate negative IGBT terminals are available for each phase to support the widest variety of control algorithms.
FSBB30CH60D主要特性:
• UL Certified No. E209204 (UL1557)
• 600 V - 30 A 3-Phase IGBT Inverter with Integral Gate Drivers and Protection..
查看全文
