Keywords:Buck regulater , boost-buck regulater, CS51413
摘要:CS51411演示板是一个允许CS5141X 系列, 此系列是1.0 A/3.3 V降压稳压器,运行在260千赫或520千赫。通过供给时钟信号的同步输入的开关频率可以同步到一个更高的频率。并驱动SHDNB输入低关闭转换器的输出,最大限度地减少了功耗。
基本特性:
The CS5141X products are 1.5A buck regulator ICs. These devices are fixed- frequency operating at 260kHz and 520kHz. The regulators use the V2 control architecture to provide unmatched transient response, the best overall regulation and the simplest loop compensation for today’s high- speed logic. These products accommodate input voltages from 4.5V to 40V.
The CS51411 and CS51413 contain synchronization circuitry.
分享到:
