Freescale的3轴多功能数字加速度计解决方案
关键词:3轴 数字加速度计 MMA8491Q 物联网
时间:2013-09-17 10:52:15       作者:Freescale       来源:中电网
Keywords: 3-Axis,Digital Accelerometer, MMA8491Q
摘要:本演示板提供检测传感器演示使用的Xtrinsic MMA8491Q45°倾斜传感器和3轴加速度计,并且使用了一个透明的塑料外壳。
基本特性:
The MMA8491Q is a low voltage, 3-axis low-g accelerometer housed in a 3 mm x 3 mm QFN package. The device can accommodate two accelerometer configurations, acting as either a 45° tilt sensor or a digital output accelerometer with I2C bus.
• As a 45° Tilt Sensor, the MMA8491Q device offers extreme ease of implementation by using a single line output per axis.
• As a digital output accelerometer, the 14-bit ±8g accelerometer data can be read from the device with a 1 mg/LSB sensitivity. The extreme low power capabilities of the MMA8491Q will reduce the low data rate current consumption to less than 400 nA per Hz.
Features
• Extreme low power, 400 nA per Hz
• Ultra-fast data output time, ~700 s
• 1.95V to 3.6V VDD supply range
• 3 mm x 3 mm, 0.65 mm pitch with visual solder joint inspection
• ±8g full-scale range
• 14-bit digital output, 1 mg/LSB sensitivity
• Output Data Rate (ODR), implementation based from < 1 Hz to 800 Hz..
查看全文
