TI LM5046 直流电源转换评估参考设计方案
关键词:直流电源转换 TI LM5046
时间:2013-08-19 14:14:23       来源:中电网
TI公司的LM5046是一款可实现电流模式或电压模式的全桥式拓扑PWM功率控制转换器芯片,该芯片主要解决输入最高电压达100V的原级隔离DC-DC转换器。具有电流限制、可编程软启动、同步整流软启动和热关断等特性。本文首先介绍芯片的简介、特性及内部框图,并给出相应设计方案的设计原理图、元器件列表及PCB元件布局图。
The LM5046 PWM controller contains all of the features necessary to implement a Phase-Shifted Full-Bridge topology power converter using either current mode or voltage mode control. This device is intended to operate on the primary side of an isolated dc-dc converter with input voltage up to 100V. This highly integrated controller-driver provides dual 2A high and low side gate drivers for the four external bridge MOSFETs, plus control signals for the secondary side synchronous rectifier MOSFETs. External resistors program the dead-time to enable zero-volt switching of the primary FETs. Intelligent startup of the synchronous rectifiers allows monotonic turn-on of the power converter even with pre-bias load conditions. Additional features include cycle-bycycle current limiting, hiccup mode restart,programmable soft-start, synchronous rectifier softstart and a 2 MHz capable oscillator with synchronization capability and thermal shutdown.
LM5046主要特性:
查看全文
