TI TPS54061 60V 200mA直流电源转换解决方案
关键词:电源管理 DC/DC转换器 开关电源
时间:2012-06-15 10:54:08       作者:TI       来源:TPS54061
TI 公司的TPS54061是集成了高边和低边MOSFET的 60V 200mA同步降压DC/DC转换器,采用电流模式控制,简化外部补偿和灵活选择元件,工作静态电流90uA,关端电流1.4uA,开关频率50kHz到1100kHz可调,主要用在4-20mA电流回路传感器,工业过程控制,计量和安全系统,高效地替代高压线性稳压器.本文介绍了TPS54061主要特性,方框图,CCM和DCM应用电路图以及TPS54061EVM-142评估板电路图,材料清单和PCB元件布局图.
The TPS54061 device is a 60-V, 200-mA,synchronous step-down DC-DC converter with integrated high side and low side MOSFETs. Current  mode control provides simple external compensation and flexible component selection. The non-switching supply current is 90 μA. Using the enable pin, shutdown supply current is reduced to 1.4 μA.
To increase light load efficiency the low side  MOSFET emulates a diode when the inductor current reaches zero.
Under voltage lockout is internally set at 4.5 V, but can be increased using two resistors on the enable pin. The output voltage startup ramp is controlled by  the internal slow start time.
The adjustable switching frequency range allows  efficiency and external component size to be  optimized. Frequency foldback and thermal shutdown  protects the part during an overload condition.
查看全文
