NXP 无线模块BUF725 简介:
NXP的BUF725的可应用在GPS 的外置电线中。
其特点表现为:1)截止频率可以做到一百GHz以上, 可以很好的工作在10GHz频率以下。
2)与硅工艺兼容,易与CMOS 集成
3)相对GaAs,有成本优势
4)从性能来说,SiGe 射频器件噪声低,开关速度快,温度特性好,输出功率大,效率高。
特征描述:
The BFU725F/N1 is a wideband silicon germanium amplifier transistor for high speed,
low-noise applications. The transistor is designed to be used for LNA applications up to
15 GHz such as GPS, satellite radio, cordless phone, wireless LAN and satellite LNB. The
BFU725F/N1 is packaged in a SOT343F that has 2 emitter pins to reduce emitter
inductance (for maximum gain).
The BFU725F/N1 is ideal for applications where cost is a concern. It also gives thedesigner flexibility in his design work, for bias current, frequency of operation,noise-figure, gain and P1dB.
方案介绍:
The demonstration boardenables testing of the device performance and requires no additional support circuitry.
分享到:
