OnSemi NCP1271 19V,3.0A通用AC-DC适配器设计方案
关键词:OnSemi NCP1271
时间:2012-11-02 14:31:31       作者:OnSemi       来源:中电网
OnSemi公司的NCP1271是一款最新的固定频率电流模式PWM开关控制器,具有为低级声频噪声提供可调节的Soft-Skip待机操作模式,为节省待机功耗内部集成高压启动,过载故障检测定时器,内部锁保护功能特性。本文首先介绍NCP1271、基本特性、内部框图及应用领域,并给出相应设计方案的设计原理图、元器件列表及PCB元件布局图。
The NCP1271 represents a new, pin to pin compatible, generation of the successful 7−pin current mode NCP12XX product series. The controller allows for excellent stand by power consumption by use of its adjustable Soft−Skip mode and integrated high voltage startup
FET. This proprietary Soft−Skip also dramatically reduces the risk of acoustic noise. This allows the use of inexpensive transformers and capacitors in the clamping network. Internal frequency jittering,ramp compensation, timer−based fault detection and a latch input make this controller an excellent candidate for converters where ruggedness and component cost are the key constraints.
NCP1271主要特性:
• Fixed−Frequency Current−Mode Operation with Ramp Compensation and Skip Cycle in Standby Condition
• Timer−Based Fault Protection for Improved Overload Detection
• “Soft−Skip Mode” Technique for Optimal Noise Control in Standby
查看全文
