On Semi NCV7381单路FlexRay总线驱动解决方案
关键词:汽车电子 FlexRay总线
时间:2012-09-07 13:43:04       作者:On Semi       来源:NCV7381
On Semi 公司的NCV7381是单路FlexRay总线驱动器,和FlexRay电物理层指标Rev.3.0.1兼容,通信速度高达10Mbps,在有线的FlexRay通信中提供差分通信媒界,具有极好的EMC和ESD性能,工作温度−40°C 到+125°C,符合汽车级质量标准.本文介绍了NCV7381主要特性,框图和应用框图,FlexRay总线驱动器应用电路图以及NCV7381 APP V2评估板主要特性,框图,电路图,元件清单和PCB布局图.
NCV7381 is a single−channel FlexRay bus driver compliant with the FlexRay Electrical Physical Layer Specification Rev. 3.0.1, capable of communicating at speeds of up to 10 Mbit/s. It provides differential transmit and receive capability between a wired FlexRay communication medium on one side and a protocol controller and a host on the other side. NCV7381 mode control functionality is optimized for nodes permanently connected to car battery.
It offers excellent EMC and ESD performance.
NCV7381主要特性:
General
• Compliant with FlexRay Electrical Physical Layer Specification Rev 3.0.1
• FlexRay Transmitter and Receiver in Normal−power Modes for Communication up to 10 Mbit/s
• Support of 60 ns Bit Time
• FlexRay Low−power Mode Receiver for Remote Wakeup Detection
查看全文
