ADI ADSP-BF527 EZ-KIT Lite评估开发方案
关键词:通信技术 网络通信
时间:2012-05-28 10:56:01       作者:ADI       来源:中电网
ADI公司的ADSP-BF52x是600MHz高性能Blackfin处理器,采用ADI/Intel的微信号架构(MSA),包括了双MAC的信号处理引擎,RISC类微处理器指令以及SIMD多媒体功能.而ADSP-BF527 EZ-KIT Lite评估板通过基于USB PC主机的高性价比评估 DSP-BF527的平台.本文介绍了ADSP-BF52x主要特性,方框图,ADSP-BF527 EZ-KIT Lite评估板主要特性,系统框图,电路图,材料清单和PCB布局图.
The ADSP-BF52x processors are members of the Blackfin family of products, incorporating the Analog Devices/Intel Micro Signal Architecture (MSA). Blackfin® processors combine a dual-MAC state-of-the-art signal processing engine, the advantages of a clean, orthogonal RISC-like microprocessor instruction set, and single-instruction, multiple-data (SIMD) multimedia capabilities into a single instruction-set architecture.
The ADSP-BF52x processors are completely code compatible with other Blackfin processors. The ADSP-BF523/ ADSP-BF525/ADSP-BF527 processors offer performance up to 600 MHz. The ADSP-BF522/ADSP-BF524/ADSP-BF526 processors offer performance up to 400 MHz and reduced static power consumption.
ADSP-BF52x主要特性:
Up to 600MHz high performance Blackfin processor
Two 16-bit MACs, two 40-bit ALUs, four 8-bit video ALUs, 40-bit shifter
查看全文
