ST公司的 STEVAL-ISV002V2 是能连接到电网的3kW光伏电压转换器开发板,包括高频绝缘输入功率部分(实现DC/DC转换)和逆变器部分(提供50Hz正弦波电流到电网),输入电压范围从200V到400V,系统输出通过LCL滤波器以230Vrms 50Hz连到电网,正常输出功率3kW.本文介绍了STEVAL-ISV002V2 主要特性,硬件方框图,控制方框图和MPPT算法方框图,以及系统指标,完整电路图和材料清单.
Interest in photovoltaic (PV) applications has grown exponentially in recent years. As PV systems require an electronic interface to be connected to the grid or standalone loads, the PV market is increasingly appealing for many power electronics manufacturers.
The STEVAL-ISV002V2 demonstration board implements a conversion system for PV applications with the aim of achieving high efficiency and significant reduction in production costs. It consists of a high-frequency isolated input power section which performs the DC-DC conversion, and an inverter section capable of delivering sinusoidal current at 50 Hz to the grid.
The system operates with input voltages in the range of 200 V to 400 V, and is tied to the grid at 230 Vrms, 50 Hz, through an LCL filter.
Other unique characteristics of the proposed converter are integration level, decoupled active and reactive power control and flexibility towards the source.
分享到:
