Infineon ICE2QS03G 36W(12V3A)电源解决方案
关键词:电源管理 AC/DC转换器 开关电源 SMPC PWM
时间:2012-02-21 11:13:18       作者:Infineon       来源:ICE2QS03G
Infineon公司的ICE2QS03G是准谐振PWM控制器,适用于离线开关电源如LCD TV,CRT TV和笔记本电脑适配器.采用突发模式操作,待机时具有超低功耗.器件采用BiCMOS技术,高达26V工作电压.本文介绍了ICE2QS03G亮点,主要特性,方框图和典型应用电路,以及36W评估板主要指标,电路图,材料清单和PCB布局图.
ICE2QS03G is a quasi-resonant PWM controller optimized for off-line switch power supply applications such as LCD TV, CRT TV and notebook adapter. The digital frequency reduction with decreasing load enables a quasi-resonant operation till very low load. As a result, the overall system efficiency is significantly improved compared to other conventional solutions. The active burst mode operation enables an ultra-low power consumption at standby mode with small and controllable output voltage ripple. Based on the BiCMOS technology, the product has a wide operation range (up to 26V) of IC power supply and lower power consumption. The numerous protection functions give a full protection of the power supply system in failure situations. All of these make the ICE2QS03G an outstanding controller for quasi-resonant flyback converter in the market.
ICE2QS03G亮点:
• Active burst mode for low standby power
• Digital frequency reduction for better overall system efficiency
查看全文
