Maxim MAX16834 112W长串LED驱动参考设计
关键词:电源管理 LED驱动器 DC/DC转换器
时间:2012-01-05 13:49:31       作者:Maxim       来源:MAX16834
Maxim公司的MAX16834是电流模式高亮LED(HB LED),可采用升压,升压-降压,SEPIC和高边降压拓扑.除了能驱动用于开关控制的N沟功率MOSFET,还能驱动N沟PWM调光开关,输入工作电压4.75V到28V,工作频率100kHz-1MHz,3000:1 PWM调光/模拟调光,主要用在单串LED LCD背光,汽车前后灯照明,投映系统RGB LED光源,DC/DC升压/升-降压转换器以及MR16,M111照明灯.本文介绍了MAX16834主要特性,方框图,各种应用电路以及采用全陶瓷电容的112W长串LED升压驱动器参考设计特性,电路图,PCB布局图.
The MAX16834 is a current-mode high-brightness LED (HB LED) driver for boost, boost-buck, SEPIC, and highside buck topologies. In addition to driving an n-channel power MOSFET switch controlled by the switching controller, it also drives an n-channel PWM dimming switch to achieve LED PWM dimming. The MAX16834 integrates all the building blocks necessary to implement a fixed-frequency HB LED driver with wide-range dimming control.
查看全文
