Infinoen ICE2QR0665 40W 20V离线开关电源解决方案
关键词:电源管理 AC/DC转换器 SMPS 开关电源 CoolSET
时间:2011-10-28 11:40:39       作者:Infinoen       来源:ICE2QR0665
Infinoen公司的CoolSET®-Q1系列ICE2QR0665是准谐振的功率集成电路,集成了带起动单元的650V CoolMOS,能工作在非常低的负载,突发模式的待机功耗小于0.1W,内置了数字软起动,主要用在LCD监视器, DVD R/W, DVD,蓝光DVD,机顶盒等.本文介绍了ICE2QR0665产品亮点和主要特性, 方框图和典型应用电路以及40W/20V评估板主要指标,电路图和材料清单,PCB布局图.
The CoolSET®-Q1 series (ICE2QRxx65) is the first generation of quasi-resonant integarted power ICs. It is optimized for off-line switch mode power supply applications such as LCD monitor, DVD R/W, DVD Combo, Blue-ray DVD, set top box, etc. Operting the MOSFET switch in quasi-resonant mode, lower EMI, higher efficiency and lower voltage stress on secondary diodes are expected for the SMPS. Based on the BiCMOS technology, the CoolSET®-Q1 series has a wide operation range (up to 25V) of IC power supply and lower power consumption. It also offers many advantages such as: a quasi-resonant operation till very low load increasing the average system efficiency compared to other conventional solutions; the Active Burst Mode operation enables an ultra-low power consumption at standby mode with small and controllable output voltage ripple.
ICE2QR0665产品亮点:
• Quasi resonant operation
查看全文
