Linear LTC2991八路I2C电压电流和温度监测方案
关键词:工业控制 I2C 电压监测 电流监测 温度监测
时间:2011-09-20 11:32:07       作者:Linear       来源:LTC2991
Linear公司的LTC2991是八路I2C串口的系统电压,电流和温度监测器,温度测量精度为0.7度C,分辨率为0.06度C,PWM温度输出,采用14位ADC来测量电压/电流,工作电压3V到5.5V,内部有10ppm/℃的基准电压,主要用在温度测量,电源监测,电流测量,遥控数据采集和环境监测.本文介绍了LTC2991主要特性,方框图,以及包括马达保护和调整电路, 计算机电压和温度监测电路与电池监测电路在内的多种应用电路.
LTC2991: Octal I2C Voltage, Current, and Temperature Monitor
The LTC.2991 is used to monitor system temperatures, voltages and currents. Through the I2C serial interface, the eight monitors can individually measure supply voltages and can be paired for differential measurements of current sense resistors or temperature sensing transistors.
Additional measurements include internal temperature and internal VCC. The internal 10ppm reference minimizes the number of supporting components and area required.Selectable address and configurable functionality give the LTC2991 flexibility to be incorporated in various systems needing temperature, voltage or current data. The LTC2991 fits well in systems needing submillivolt voltage resolution, 1% current measurement and 1℃ temperature accuracy or any combination of the three.
LTC2991主要特性:
Measures Voltage, Current, Temperature
Measures Four Remote Diode Temperatures
查看全文
