ADI公司的ADM1066是可配置的单片多种电源监视/定序器件,并集成了12位ADC和6个8位电压输出的DAC,所有电压在25度C的精度优于0.5%,主要用在中心办公系统,服务器/路由器,多电压系统线路卡,DSP/FPGA电压定序等.本文介绍了ADM1066主要特性,方框图, 应用框图以及ADM106x评估板主要特性,方框图和电路图,材料清单.
The ADM1066 Super Sequencer® is a configurable supervisory/ sequencing device that offers a single-chip solution for supply monitoring and sequencing in multiple-supply systems. In addition to these functions, the ADM1066 integrates a 12-bit ADC and six 8-bit voltage output DACs. These circuits can be used to implement a closed-loop margining system that enables supply adjustment by altering either the feedback node or reference of a dc-to-dc converter using the DAC outputs.
Supply margining can be performed with a minimum of external components. The margining loop can be used for in-circuit testing of a board during production (for example, to verify board func-tionality at −5% of nominal supplies), or it can be used dynamically to accurately control the output voltage of a dc-to-dc converter。
ADM1066主要特性:
Complete supervisory and sequencing solution for up to 10 supplies
10 supply fault detectors enable supervision of supplies to
分享到:
