Microchip dsPIC33FJ16系列高性能低成本马达控制方案
关键词:工业控制 马达控制
时间:2011-06-29 11:31:56       作者:Microchip       来源:dsPIC33FJ16
Microchip 公司的dsPIC33FJ16GP101/102和dsPIC33FJ16MC101/102 是高性能超低成本数字信号控制器(DSC),包含了DSP功能和高性能16位MCU架构,3.0V-3.6V的性能高达16MIPS,可扩展的工作温度-40℃到 +125℃,主要用在家用电器如洗衣机,医疗设备如输液泵,工业如AC马达等.本文介绍dsPIC33FJ16系列主要特性,方框图,CPU核方框图和应用电路以及马达控制板系统框图,电路图和材料清单(BOM)。
This document contains device specific information for the dsPIC33FJ16GP101/102 and
dsPIC33FJ16MC101/102 Digital Signal Controller(DSC) Devices. The dsPIC33F devices containextensive Digital Signal Processor (DSP) functionality with a high-performance, 16-bit microcontroller (MCU) architecture.
dsPIC33FJ16系列主要特性:
Operating Range:
• Up to 16 MIPS operation (3.0V-3.6V):
- Industrial temperature range (-40℃ to +85℃)
- Extended temperature range (-40℃ to +125℃)
On-Chip Flash and SRAM:
• Flash program memory (16 Kbytes)
• Data SRAM (1 Kbyte)
• Security for program Flash
System Management:
• Flexible clock options:
- External, crystal, resonator, internal FRC
- Phase-Locked Loop (PLL)
• High-accuracy internal FRC
- ±0.25% typical
• Power-on Reset (POR)
• Power-up Timer (PWRT)
查看全文
