TI公司的ADS5263是采用CMOS工艺技术的具有低噪音16位前端和14位ADC的低功耗非常高SNR性能的集成电路,SNR可达85dBFS(10MHz),30MHz时可达80dBFS,最大取样速率00 MSPS,可编程增益0 dB 到12 dB,主要用在医疗成像如MRI, 波谱学和CCD图像.本文介绍了ADS5263主要特性,方框图, 数字处理框图以及ADS5263EVM评估板电路图,材料清单和元件布局图.
Using CMOS process technology and innovative circuit techniques, the ADS5263 is designed to operate at low power and give very high SNR performance with a 4-Vpp full-scale input. Using a low-noise 16-bit front-end stage followed by a 14-bit ADC, the device gives 85-dBFS SNR up to 10 MHz and better than 80-dBFS SNR up to 30 MHz.
The device also has a 14-bit low power mode, where it operates as a quad-channel 14-bit ADC. The 16-bit front-end stage is powered down and the part consumes almost half the power, compared to the 16-bit mode. The 14-bit mode supports a 2-Vpp full-scale input signal, with typical 74-dBFS SNR. The ADS5263 can be dynamically switched between the two resolution modes. This allows systems to use the same part in a high-resolution, high-power mode or a low-resolution, low-power mode.
ADS5263主要特性:
Maximum Sample Rate: 100 MSPS
Programmable Device Resolution
Quad-Channel, 16-Bit, High-SNR Mode
分享到:
