SMSC LAN88710 MII-MRII以太网收发方案
关键词:通信技术 以太网收发器 PHY 消费类电子 HDTV STB
时间:2009-09-07 14:13:00       来源:SMSC, , ,
SMSC 公司的LAN88710是采用HP Auto-MDIX 和flexPWR®技术的MII/MRII 10/100以太网收发器,并集成1.2V线性电压稳压器和ESD保护元件,具有业界最小的占位面积,比现有的SMSC收发器功耗要低40%以上,I/O电压从3.6V到1.6V,主要用于消费类电子产品如HDTV,STB,DVR,PVR,以及网络打印机和服务器,游戏机,通信和POS终端与工业和企业应用.本文介绍了LAN88710主要特性, 架构框图, 系统方框图, 简化应用框图, 铜双绞线接口框图以及EVB8710 PHY评估板主要特性,电路图和材料清单.
LAN8710: MII/RMII 10/100 Ethernet Transceiver with HP Auto-MDIX and flexPWR® Technology in a Small Footprint
SMSCs LAN8710 and LAN8720 are high-performance, small-footprint, low-power 10BASE-T/100BASE-TX transceivers specifically designed for todays consumer electronics, industrial and enterprise applications. The LAN8710/8720 are the industrys smallest footprint solutions with up to 40% lower power consumption than existing SMSC transceivers. The LAN8710/8720 have an integrated voltage regulator and ESD protection components to help reduce Bill of Material (BOM) costs.
查看全文
