NXP公司的TEA152x系列STARplug是开关电源(SMPS)控制器,能直接连接到火线整流后的高压.器件采用高压EZ-HV SOI工艺和低压双极互补MOS(BiCMOS)工艺制造,集成了650V高压开关,火线工作电压从80 V到276 V,可提供的功率高达30W,有广泛的用途,包括充电器,适配器,STB,DVD,TV/监视器电源,PC外设和MCU电源等.本文介绍了TEA152x主要特性和优势,方框图,多种应用和STARbuck评估板主要特性,电路图和所用元器件.
TEA152x: SMPS ICs for low-power systems
The TEA152x family STARplug is a Switched Mode Power Supply (SMPS) controller IC that operates directly from the rectified universal mains. It is implemented in the high-voltage EZ-HV SOI process, combined with a low-voltage Bipolar Complementary Metal-Oxide Semiconductor (BiCMOS) process.
The device includes a high-voltage power switch and a circuit for start-up directly from the rectified mains voltage. A dedicated circuit for valley switching is built in, which makes a very efficient slim-line electronic power-plug concept possible.In its most basic version of application, the TEA152x family acts as a voltage source.Here, no additional secondary electronics are required. A combined voltage and current source can be realized with minimum costs for external components. Implementation of the TEA152x family renders an efficient and low cost power supply system.
TEA152x主要特性和优势:..
分享到:
