NXP TEA1733LT GreenChip开关电源控制方案
关键词:电源管理 AC/DC转换器 开关电源 SMPS
时间:2011-01-28 09:46:36       作者:NXP       来源:TEA1733LT
NXP公司的TEA1733LT/N1 和TEA1733LT/N2是低成本 GreenChip 开关电源(SMPS)控制器,适合用于反激拓扑。器件工作在固定频率模式,采用频率抖动来降低电磁干扰(EMI),输入电压12V-30V,起动和重起的电流非常低,只有10uA,无负载时的工作电流0.5mA,适用于75W以下的开关电源。本文介绍了TEA1733LT/N1 和TEA1733LT/N2主要特性和优势,TEA1733LT/N1 和TEA1733LT/N2方框图,典型应用电路图以及GreenChip 65 W TEA1733(L)T演示板主要特性,电路图和材料清单(BOM)。
TEA1733LT:GreenChip SMPS control IC
The TEA1733LT/N1 and TEA1733LT/N2 are low cost Switched Mode Power Supply (SMPS) controller ICs intended for flyback topologies. They operate in fixed frequency mode. To reduce ElectroMagnetic Interference (EMI), frequency jitter has been implemented. Slope compensation is integrated for Continuous Conduction Mode (CCM) operation.
The TEA1733LT includes OverPower Protection (OPP). This enables the controller to operate under overpower situations for a limited amount of time.
查看全文
