Avago ADNS-2080低功耗光学鼠标解决方案
关键词:计算机于外设 光学鼠标传感器
时间:2010-12-29 09:43:28      来源:ADNS
Avago公司的ADNS-2080是低功耗小型光学鼠标传感器,高速运动检测高达30jps和20g,可选择的高达2000cpi,工作电压低到2.1V,IO基准电压1.7V-3.3V,2线串行接口,主要用于光学鼠标和光学跟踪球,集成输入设备和以电池为动力的输入设备.本文介绍了ADNS-2080主要特性, 光学鼠标方框图, 主板(无绳应用)电路图, RF模块电路图和加密狗电路图.
ADNS-2080: Low Power Optical Mouse Sensor
The Avago Technologies ADNS-2080 is a low power, small form factor optical mouse sensor. It has a new low-power architecture and automatic power management modes, making it ideal for battery, power-sensitive applications – such as cordless input devices. The ADNS-2080 is capable of high-speed motion detection – up to 30 ips and 20 g. In addition, it has an on-chip oscillator and requires an external resistor to set the LED
current.
The ADNS-2080 along with the ADNS-5110-001 lens, ADNS-5200 clip, and HSDL-4261 IR LED, or HLMP-EG3E Red LED form a complete and compact mouse tracking system. There are no moving parts and this translates to high reliability and less maintenance for the end user. In addition, precision optical alignment is not required, facilitating high volume assembly.
The sensor is programmed via registers through a twowire serial port. It is housed in an 8-pin staggered dual in-line package (DIP).
ADNS-2080主要特性:
Low Power Architecture
Small Form Factor
Programmable Periods / Response Times and Downshift Times from one mode to another for the Power-saving Modes
High Speed Motion Detection up to 30 ips and 20 g
External Interrupt Output for Motion Detection
Internal Oscillator – no clock input needed
Selectable Resolution of up to 2000 cpi
Operating Voltage: as low as 2.1 V
IO reference voltage of 1.7 V to 3.3 V
2-wire serial port interface
ADNS-2080应用:
Optical mice and optical trackballs
Integrated input devices
Battery-powered input devices
图1.ADNS-2080光学鼠标方框图
图2.ADNS-2080-LG主板(无绳应用)电路图
图3.作为主板附件...
  • 时 间:2026年5月19日
