Intersil 公司的ZL6001是数字DC/DC电源控制器,集成了3A MOSFET驱动器,均流特性允许多个器件并联连接给负载供电,以满足更高电流的需求.输入电压3V-14V,输出电压0.54V-5.5V,输出电压精度±1%,并具有快速负载瞬态响应,集成了和PMBus兼容的I2C/SMBus接口,主要用在服务器/存储器设备,通信/数据通信设备以及电源模块.本文介绍了ZL6001主要特性,方框图, 12V输入输出1.8V/20A应用电路图,均流方框图以及ZL6100EVAL1Z评估板主要特性和指标,电路图,PCB布局图和材料清单.
The ZL6100 is a digital DC/DC controller with integrated MOSFET drivers. Current sharing allows multiple devices to be connected in parallel to source loads with very high current demands. Adaptive performance optimization algorithms improve power conversion efficiency across the entire load range. Zilker Labs Digital-DC™ technology enables a blend of power conversion performance and power management features.
分享到:
