关键词:电源管理 AC/DC转换器 LED驱动器 开关电源 SMPS
时间:2010-11-30 11:01:33 作者:NXP 来源:SSL2103
NXP 公司的SSL2103是多用途开关电源(SMPS)控制器,是一款多用途AC/DC LED照明控制器,具有更宽的功率适用范围和更好的调光兼容性,令其适用于可调及不可调LED照明灯,SSL2103在正常工作温度下的寿命可以超过75000小时。主要应用于100V、110V或230V的交流电源网络,电路板外形尺寸可以应用于E27、GU10或者PARx 灯。本文介绍了SSL2103主要特性和优势,方框图以及降压和反激配置框图。
SSL2103: SMPS controller IC for dimmable LED lighting
SSL2103 is a Switched Mode Power Supply (SMPS) controller IC designed for LED lighting applications. It is an extension of the NXP SSL2101/SSL2102 product platform,allowing easy design of derivative applications.
When used in combination with a phase cut dimmer connected directly to a rectified mains, it provides dimmability to the application.In dimmer applications, integrated dedicated circuitry optimizes the dimming curve.
• SSL2101: fully integrated LED driver for lamps up to 10 W
• SSL2102: fully integrated LED driver for lamps up to 25 W
• SSL2103: gives the application designer flexibility permitting the:
– control of an external power switch to allow the IC to provide any power
– control of external bleeder transistors to provide extended dimmer interoperability
分享到:
