Silabs Si4313单端通用ISM频段接收方案
关键词:消费类电子 遥控 健康监视器
时间:2010-08-26 10:07:59       作者:Silabs       来源:Si4313
Silabs 公司的Si4313是单端通用ISM频段接收器,工作频率240–960 MHz,灵敏度–118 dBm,数据速率0.2 - 128 kbps,采用FSK, GFSK和OOK调制方案,电源电压1.8 到3.6 V,主要用在遥控,健康监视器,气象站和个人数据资料记录。本文介绍了Si4313主要特性,功能方框图,应用案例图和参考测试板电路图。
The Si4313 is a single-ended universal ISM receiver for cost-sensitive applications featuring technology developed for the EZRadioPRO® product family.
The Si4313 offers a simple, single-ended radio implementation over the 240–960 MHz frequency range. A receive sensitivity of up to –118 dBm allows for the creation of communication links with an extended range. The Si4313 offers excellent receiver performance in cost-sensitive radio applications.
The Si4313 provides designers with advanced features to enable low system power consumption by offloading a number of RF-related activities from the system MCU allowing for extended MCU sleep periods.
Additional features, such as an automatic wake-up timer, 64-byte RX FIFO, and a preamble detection circuit, are available. The Si4313’s digital receive architecture features an ADC and DSP based modem that performs the radio demodulation and filtering for increased performance.
Si4313主要特性:
Frequency range = 240–960 MHz..
查看全文
