NS LMH2120 6GHz线性RMS功率检测方案
关键词:通信技术 WCDMA LTE
时间:2010-08-25 10:07:00       作者:NS       来源:LMH2120
NS 公司的LMH2120是6GHz线性RMS功率检测器,动态范围40dB,工作频率从50 MHz到6 GHz,一致性优于±0.5 dB,对温度不敏感,工作电压2.7V-5.0V,主要用在多模式多频段功率控制如GSM/EDGE,CDMA/CDMA2000,WCDMA,OFDMA和LTE,基础设备的RF功率控制。本文介绍了LMH2120主要特性,方框图,发送功率控制系统框图,应用电路以及LMH2120 评估板电路图和LMH2120 评估板材清单。
6 GHz Linear RMS Power Detector with 40 dB Dynamic
The LMH2120 is a 40 dB Linear RMS power detector particularly suited for accurate power measurement of modulated RF signals that exhibit large peak-to-average ratios, i.e, large variations of the signal envelope. Such signals are encountered in W-CDMA and LTE cell phones. The RMS measurement topology inherently ensures a modulation insensitive measurement.
查看全文
