Infineon ICL8001G准谐振模式LED驱动方案
关键词:电源管理 LED驱动器 AC/DC转换器
时间:2010-08-16 09:52:06       作者:Infineon       来源:ICL8001G
Infineon公司的 ICL8001G是准谐振模式LED驱动器,精密的PWM可用于相位调光,功率因素大于98%,效率高达90%,工作电压高达26V。本文介绍了ICL8001G主要特性和亮点,方框图以及初级控制应用电路图和EVAL-LED-ICL8001G-Bulb02演示板主要特性,电路图,材料清单和变压电路图。
The ICL8001G employs quasi-resonant operation mode optimized for off-line LED lighting, especially dimmable LED bulbs for incandescent lamp replacement. Precise PWM generation enables primary control for phase cut dimming and high power factor PF>98%. Significant improved driver efficiency, up to 90%, compared to other conventional solutions. The product has a wide operation range (up to 26V) of IC voltage supply and lower power consumption. Multiple safety functions ensure a full system protection in failure situations. With its full feature set and simple application, the ICL8001G represents an outstanding choice for quasi-resonant flyback LED bulb designs combining feature set and performance at minimum BOM cost.
ICL8001G 产品亮点:
• Quasi-Resonant Control For Highly Efficient LED Driving Solutions
• Primary Side Flyback Control With Integrated PFC And Phase-Cut Dimming
• Integrated HV Startup Cell For Short Time To Light
查看全文
