Infineon EVALLED-TDA4863G-40W LED驱动方案
关键词:电源管理 LED驱动器
时间:2010-08-10 09:49:21       作者:Infineon       来源:EVALLED
Infineon 公司的EVALLED-TDA4863G-40W 评估板是单级效率达90%的离线LED驱动电源。该评估板采用TDA4863G和TLE4305G两个器件,效率高达90%,功率因素高达0.98,THD低,恒流恒压稳压精度+/- 2%,具有VCC过压和欠压保护,可以逐个周期对峰值电流进行限制。本文介绍了TDA4863主要特性和应用电路,EVALLED-TDA4863G-40W评估板主要特性,电路图,材料清单和变压器电路图。
Single Stage High Power Factor Flyback Converter for Offline LED Supply
TDA4863 Power Factor Controller IC for High Power Factor and Low THD
The TDA4863 IC controls a boost converter in a way that sinusoidal current is taken from the single phase line supply and stabilized DC voltage is available at the output. This active harmonic filter limits the harmonic currents resulting from the capacitor pulsed charge currents during rectification. The power factor which describes the ratio between active and apparent power is almost one. Line voltage fluctuations can be compensated very efficiently.
TDA4863主要特性:
• IC for sinusoidal line-current consumption
• Power factor achieves nearly 1
• Controls boost converter as active harmonic filter for low THD
• Start up with low current consumption
• Zero current detector for discontinuous operation mode
查看全文
