NXP BGA7127 400-2700MHz 0.5W高线性放大方案
关键词:通信技术 无线通信 RFID WLAN
时间:2010-08-10 09:44:22       作者:NXP       来源:BGA7127
NXP公司的BGA7127是 400-2700MHz 0.5W高线性硅放大器,1dB压缩点的输出功率为28dBm,2GHz的小信号增益为12dB,单电源5V工作,主要用在宽带CPE/MoCA,工业,WLAN/ISM/RFID,电子仪表,无线基础设备如基站等,卫星天线电视(SMATV)。本文介绍了BGA7127主要特性和优势,功能方框图以及920 MHz 到 960 MHz,1930 MHz 到 1990 MHz,2110 MHz 到 2170 MHz和2405 MHz 到 2485 MHz的应用电路及相应的材料清单。
BGA7127:400 MHz to 2700 MHz 0.5 W high linearity silicon amplifier
The MMIC is a one-stage amplifier, offered in a low-cost leadless surface-mount package. It delivers 28 dBm output power at 1 dB gain compression and a superior performance up to 2700 MHz. Its power saving features include simple quiescent current adjustment, which allows class-AB operation and logic-level shutdown control to reduce the supply current to 4 μA.
BGA7127主要特性和优势:
400 MHz to 2700 MHz frequency operating range
12 dB small signal gain at 2 GHz
Integrated active biasing
External matching allows broad application optimization of the electrical performance
5 V single supply operation
All pins ESD protected
BGA7127应用:
Broadband CPE/MoCA
Industrial applications
WLAN/ISM/RFID
E-metering
查看全文
