Supertex HV9963高压LED驱动方案
关键词:电源管理 LED驱动器 DC/DC转换器
时间:2010-08-03 09:50:21       作者:Supertex       来源:HV9963
Supertex公司的HV9963是电流模式控制的LED驱动器,能用来控制PWM转换器(降压,升压,升-降压或SEPIC),PWM调光比大于5000:1,内部有40V线性稳压器,±2%电压基准,可编程软起动和10V GATE驱动器,主要用在RGB或白光LED背光,电池能源LED灯,其它DC/DC LED驱动器。本文介绍HV9963主要特性,功能方框图和典型应用电路。
The HV9963 is a current mode control LED driver IC designed to control single switch PWM converters (buck, boost, buck-boost or SEPIC) in a constant frequency mode. The controller uses a peak current-mode control scheme (with programmable slope compensation) and includes an internal transconductance amplifier to accurately control the output current over all line and load conditions. Multiple HV9963s can be synchronized to each other or to an external clock using the SYNC pin. The IC also provides a disconnect switch gate drive output, which can be used to disconnect the LEDs in case of a fault condition using an external disconnect FET. The 10V external FET drivers allow the use of standard level FETs. The low voltage 5.0V AVDD is used to power the internal logic and also acts as a reference voltage to set the current level.
查看全文
