Allegro A5303新标准3V光电烟雾检测方案
关键词:工业控制 传感器 烟雾检测器
时间:2010-08-03 09:45:19       作者:Allegro       来源:A5303
Allegro 公司的A5303是低功耗BiCMOS光电烟雾检测电路,具有超低待机电流,采用便宜电池也能工作10年。工作电压2.3 到5.5 V,其可变增益光放大器直接和红外发射-检测对接口,而内置电路可降低误触发,内部的振荡器和时序电路每10秒仅用100us检测烟雾,因而是待机功耗最低化。本文介绍了A5303主要特性和优势以及方框图与典型应用电路。
The A5303 is a low-current BiCMOS photoelectric smoke detector circuit with ultra-low standby current and can operate for 10 years powered by inexpensive batteries. This device can be used with an infrared optical chamber to sense light scattered from smoke particles. A networking capability allows units to be interconnected so that if any unit senses smoke all units will sound an alarm. Special features are incorporated in the design to facilitate calibration and testing of the finished detector.
A variable-gain photoamplifier can be directly interfaced to an infrared emitter-detector pair. The amplifier gain levels are determined by two external capacitors and are internally selected depending on the operating mode. Low gain is selected during standby and timer modes. During a local alarm, this low gain is increased (internally) by approximately 45% to provide hysteresis. High gain is used during pushbutton test and to periodically monitor the chamber sensitivity during standby.
查看全文
