Freescale 公司的i.MX35系列是汽车多媒体应用处理器,包括i.MX351, i.MX355和 i.MX356等产品. i.MX35处理器采用ARM1136JF-S™内核,工作频率532MHz,集成了16KB L1指令高速缓存, 16KB L1数据高速缓存,128KB L2高速缓存,128KB SRAM以及向量浮点单元(VFP11),LCD控制器,以太网和图像加速器等,为高性能多媒体和图像应用提供了低功耗解决方案.主要应用在汽车电子音频以及音频连接.本文介绍了i.MX35系列主要特性, 简化方框图,包括CPU引擎板, 调试板和RINGO个人板在内的开发套件(PDK)方框图,电路图和材料清单(BOM).
i.MX35 Family of Multimedia Applications Processors Automotive portfolio: i.MX351, i.MX355 and i.MX356
The i.MX353 and the i.MX357 multimedia applications processors represent the next generation of ARM11 products with the right performance and integration to address applications within the industrial and consumer markets for applications such as HMI and display controllers.
Unless otherwise specified, the material in this data sheet is applicable to both the i.MX353 and i.MX357 devices and referred to singularly throughout this document as i.MX35 or MCIMX35. The i.MX353 devices do not include a graphics processing unit (GPU). For information on i.MX35 devices for automotive applications, please refer to document number, MCIMX35SR2AEC.
分享到:
