Avago 公司的ACPL-312T是包括有AlGaAs LED的汽车用光耦合器,功率输出级的最大峰值电流2.5A,非常适合用来驱动汽油马车控制逆变器和DC/DC转换器的1200 V/100 A的功率IGBT和MOSFET,VCC工作电压15-30V,开关速度500ns, 主要用于汽车马达/ DC/DC转换器,绝缘的IGBT和MOSFET栅极驱动,AC和无刷DC马达驱动,工业逆变器系统和开关电源.本文介绍ACPL-312T主要特性, LED驱动和应用电路和负IGBT栅极驱动电路.
Automotive 2.5 Amp Output Current IGBT Gate Drive Optocoupler
The ACPL-312T device contains an AlGaAs LED. The LED is optically coupled to an integrated circuit with a power output stage. This automotive optocoupler is ideally suited for driving power IGBTs and MOSFETs used in automotive motor control inverter and DC-DC converters applications. The high operating voltage range of the output stage provides the drive voltages required by gate controlled devices. The voltage and current supplied by these optocouplers make them ideally suited for directly driving IGBTs with ratings up to 1200 V/100 A. For IGBTs with higher ratings, the ACPL-312T series can be used to drive a discrete power stage which drives the IGBT gate.
Avago R2Coupler provides with reinforced insulation and reliability that delivers safe signal isolation critical in automotive and high temperature industrial applications...
分享到:
