Holtek 公司的HT7612是无源红外线(PIR)控制器, 采用新的架构及设计方式,待机电流大幅降低至仅约15uA,在应用上可减少电池耗电,延长电池使用时间,符合现代节能减碳概念之需求。工作电压2.7V ~ 5.5V,40秒上电延迟, 1~3783秒可调PIR接通时间,输出可驱动继电器,TRIAC和LED等, 工作温度范围为-40℃~ 85℃,广泛应用在感应照明、防盗警报器、访客报知器、感应门、智慧玩具等..本文介绍HT7612主要特性, 方框图以及在TRIAC, 继电器和4.5V DC电源中应用电路图.
HT7612: General Purpose PIR Controller
The HT7612 is PIR controller specifically designed to interface to PIR sensors to implement motion sensing application products such as intruder alarms. The controller has the features of PIR sensitivity adjustment and a CDS can be connected to the controller for automatic detection. The HT7612 is available in low profile NSOP & DIP packages.
HT7612主要特性:
Operating voltage: 2.7V ~ 5.5V
Standby current typical 15uA
CDS input
High noise immunity
40 second power-on delay
10 second high speed warm-up for test mode
1~3783 second adjustable PIR turn on time.
Output drive for Relay, TRIAC and LED
Output drive buzzer alarm
Low voltage detector
Override function
16-pin DIP/NSOP package
HT7612应用:
PIR light control
Motion detectors
Alarm system
分享到:
