NEC公司的 µPD168804是四路降压或升压恒流驱动器,每路的驱动电流可高达1500mA,升压或降压工作模式可通过外接元件来选择. 主要应用在加热器,低压工业照明, D背光照明等.本文介绍了µPD168804主要特性,方框图以及降压和升压应用电路图.
µPD168804:4 CH BUCK OR BOOST SELECTABLE CONSTANT CURRENT DRIVER IC WITH EXTERNAL POWER MOSFETS
The µPD168804 is a power supply control IC with four constant-current controller/driver channels. A high current drive of up to 1,500 mA per channel is supported by providing an external power MOSFET. Furthermore, operating conditions for either step-up or step-down operation can be selected and used according to the configuration of external components and settings of selected pins. The µPD168804 has separate circuits for protecting against overheating, low voltages, overcurrents, and overvoltages (step-up operation only), and can control load currents by externally inputting PWM signals.
µPD168804主要特性:
Flexible choice of Buck or Boost is available (one from Buck topology or Boost topology) by the arrangement of external Power MOSFET, Shottkey barrier diodes and other external components and MODE pin setting.
分享到:
