Microchip PIC24F16KA102 XLP开发方案
关键词:计算机和外设 微控制器 PIC24F16KA102
时间:2009-11-03 11:07:00       来源:Microchip
Microchip公司推出的PIC24F16KA102是通用,16位闪存微控制器,具有nanoWatt XLP™技术。PIC24F16KA102介绍了一系列新的极低功耗Microchip器件:具有广泛的外设功能和增强的计算性能16位微控制器系列。器件还为这些高性能应用提供了新的移动选择,这些应用性能可能已超出其8位平台,但无需数字信号处理器的数字处理能力。本文介绍了PIC24F16KA102系列方框图、PIC24FCPU核方框图、XLP 16位开发套件电路图。
功率管理模式:
• Run – CPU, Flash, SRAM and Peripherals On
• Doze – CPU Clock Runs Slower than Peripherals
• Idle – CPU Off, Flash, SRAM and Peripherals On
• Sleep – CPU, Flash and Peripherals Off and SRAM On
• Deep Sleep – CPU, Flash, SRAM and Most Peripherals Off
- Run mode currents down to 8 uA typical
- Idle mode currents down to 2 uA typical
- Deep Sleep mode currents down to 20 nA typical
- RTCC 490 nA, 32 kHz, 1.8V
- Watchdog Timer 350 nA, 1.8V typical
高性能CPU:
• Modified Harvard Architecture
• Up to 16 MIPS Operation @ 32 MHz
• 8 MHz Internal Oscillator with 4x PLL Option and Multiple Divide Options
• 17-Bit by 17-Bit Single-Cycle Hardware Multiplier
• 32-Bit by 16-Bit Hardware Divider
• 16-Bit x 16-Bit Working Register Array
查看全文
