Cypress CY4602 Tetrahub USB 2.0 4端口Hub参考设计
关键词:计算机及外设 USB Hub
时间:2009-09-16 15:31:00       来源:Cypress
Cypress公司的CY7C65640A是TetraHub高速USB Hub控制器, Tetra架构提供四个下行的USB端口,每个端口都有处理翻译器(TT). CY7C65640A集成了一个上行和四个下行USB收发器,串行接口引擎(SIE),USB 集线器(Hub)控制器和转发器以及四个TT,非常适合用在标准集线器,主板集线器和监视器集线器,外接个人存储器驱动,端口复制,手提设备和坞站.本文介绍了CY7C65640A主要特性, TetraHub架构图, CY4602 Tetrahub USB 2.0 4端口Hub参考设计方框图,电路图以及所用材料清单(BOM).
CY7C65640A: TetraHub™ High Speed USB Hub Controller
Cypress’s TetraHub™ is a high performance self powered Universal Serial Bus (USB) 2.0 hub. The Tetra architecture provides four downstream USB ports, with a Transaction Translator (TT) for each port, making it the highest performing hub possible. This single-chip device incorporates one upstream and four downstream USB transceivers, a serial Interface Engine (SIE), USB hub controller and repeater, and four TTs. It is suitable for standalone hubs, motherboard hubs, and monitor hub applications.
Being a fixed-function USB device, there is no risk or added engineering effort required for firmware development. The developer does not need to write any firmware for their  design.
查看全文
