TI 公司的TAS5707是20W高效数字音频功率放大器,能驱动桥式连接的立体声扬声器.模拟音频输入/输出, 支持8-kHz 到48-kHz取样频率,能从18V的电源向8欧姆负载提供20W功率. TAS5707的工作电压从8V到24V,采用高效的D类放大器,不需要散热器.本文介绍了TAS5707的主要特性,方框图以及TAS5707评估板的主要特性,电路图以及所用材料费清单.
The TAS5707 is a 20-W, efficient, digital audio power amplifier for driving stereo bridge-tied speakers. One serial data input allows processing of up to two discrete audio channels and seamless integration to most digital audio processors and MPEG decoders. The device accepts a wide range of input data and data rates. A fully programmable data path routes these channels to the internal speaker drivers.
The TAS5707 is a slave-only device receiving all clocks from external sources. The TAS5707 operates with a PWM carrier between 384-kHz switching rate and 352-KHz switching rate depending on the input sample rate. Oversampling combined with a fourth-order noise shaper provides a flat noise floor and excellent dynamic range from 20 Hz to 20 kHz.
主要特性:
Audio Input/Output:
20-W Into an 8-Ω Load From an 18-V Supply
Wide PVDD Range, From 8 V to 24 V
Efficient Class-D Operation Eliminates Need for Heatsinks
Requires Only 3.3 V and PVDD ..
查看全文
