Powerint公司的PKS607YN是PeakSwitch系列器件,能满足高峰值/连续功率比的应用需求.PeakSwitch系列集成了700V功率MOSFET,振荡器,用于起动的高压开关电流源,限流和热关断.此外,还包括自动重起,火线欠压检测和频率抖动等功能. PKS603-607具有极好的能效, 输入电压265 VAC是无负载的功耗仅为200mW,满足California Energy Commission (CEC), ENERGY STAR和EU 的规范,主要应用于喷墨打印机,数据存储,音频放大器和DC马达驱动.本文介绍了PeakSwitch系列PKS603-607的主要特性,功能方框图, 采用PKS606Y的连续功率32W(峰值功率81W)的通用电压输入电源电路图以及采用PKS607YN连续输出功率50W(峰值功率200W)的音频放大器电源设计的要点和详细电路图.
PeakSwitch is designed to address applications with high peak-to-continuous power ratio demands. The very high switching frequency during peak power loads and excellent load transient response reduce system cost as well as component count and size. PeakSwitch incorporates a 700 V power MOSFET, oscillator, high voltage switched current source for startup, current limit, and thermal shutdown onto a monolithic device. In addition, these devices incorporate auto-restart, line under-voltage sense and frequency jittering. An innovative design minimizes audio frequency components in the simple ON/OFF control scheme to practically eliminate audible noise with standard varnished transformer construction.
PKS603-607主要特性:
EcoSmart– Extremely Energy-Efficient ..
查看全文
