Öйúµç×Ó¼¼ÊõÍø
ÉèΪÊ×Ò³ ÍøÕ¾µØÍ¼ ¼ÓÈëÊÕ²Ø
[Ô­´´]Maxim MAX22256 36V HÇűäѹÆ÷Çý¶¯Æ÷½â¾ö·½°¸
¹Ø¼ü´Ê£ºµçÔ´¹ÜÀí ±äѹÆ÷Çý¶¯Æ÷ Maxim MAX22256
ʱ¼ä£º2022-06-17 15:46:11       À´Ô´£ºÖеçÍø
Maxim¹«Ë¾µÄMAX22256/8ϵÁвúÆ·Êǽô´ÕµÄ¸ôÀëµçÔ´36V HÇűäѹÆ÷Çý¶¯Æ÷,Ϊ³¬¹ý15WµÄ¸ôÀëµçÔ´Ìṩ¼òµ¥µÄ½â¾ö·½°¸.ÕâЩÆ÷¼þ´Ó5Vµ½36V DCµçÔ´Çý¶¯±äѹÆ÷³õ¼¶ÏßȦ,µçÁ÷¸ß´ï650mARMS. MAX22256B/C×îÊʺÏÓÚLLCÐÍгÕñÍØÆË,¸ÄÉÆÁËЧÂÊ,½µµÍ¿ª¹ØÔëÒô. MAX22256/MAX22258ϵÁоßÓеç×è¿Éµ÷ÕûµÄµçÁ÷ÏÞÖÆ,ÔÊÐí´Î¼¶±ß¸ºÔصçÁ÷¼ä½ÓÏÞÖÆ,´Ó¶øÔڴμ¶»ò¶à»òÏÖ³¡²à¹ÊÕÏʱ±£»¤³õ¼¶µçÔ´. MAX22256/MAX22258¼¯³ÉÁ˳õ¼¶±ß¿ØÖÆÆ÷ºÍHÇÅÇý¶¯Æ÷ÓñøÓÚ¸ôÀëµçÔ´µç·,¾ßÓо«ÃܵİåÉÏÕñµ´Æ÷,±£»¤µç·,ÆäÄÚ²¿MOSFETÏò±äѹÆ÷³õ¼¶ÈÆ×éÌṩ¸ß´ï650mARMSµçÁ÷.Æ÷¼þ»¹¾ßÓÐÄÚ²¿450kHz(µäÐÍ)Õñµ´Æ÷,ÄÜÓÉͬ²½ÓÚ¶à¸öÆ÷¼þµÄÍⲿʱÖÓÀ´Çý¶¯ºÍ¿ØÖÆEMI.ÄÚ²¿´¥·¢¼¶±£Ö¤Á˹̶¨50%Õ¼¿Õ±È,ÒÔ±£»¤±äѹÆ÷DCµçÁ÷Á÷¶¯,ֻҪʱÖÓÖÜÆÚÊDz»±äµÄ.µçÔ´µçѹ5Vµ½36V,ЧÂʸߴï91%.¿É±à¹ýÁ÷ãÐÖµ,¿Éµ÷ËÀÇøÊ±¼ä30nsµ½200ns(MAX22258),¹ýÁ÷ÏÞÖÆ¸ß´ï1A,¹¤×÷ζÈ-40¡ãCµ½ +125¡ãC.Ö÷ÒªÓÃÔÚ¸ôÀëÂí´ïÇý¶¯Õ¤¼«µçÔ´ºÍ¸ôÀë+24V PLCÏÖ³¡µçÔ´.±¾ÎĽéÉÜÁËMAX22256/MAX22258²úÆ·ÁÁµã,¿òͼºÍ¼ò»¯Ó¦Óÿòͼ,¶àÖÖÓ¦Óõç·ͼ,ÒÔ¼°ÆÀ¹À°åMAX22256 EVKÖ÷ÒªÌØÐÔ,µç·ͼ,²ÄÁÏÇåµ¥ºÍPCBÉè¼ÆÍ¼.
The MAX22256/MAX22258 family provides a simple solution for making isolated power supplies over 15W. These devices drive a transformers primary coil with up to 650mARMS of current from a wide 5V to 36V DC supply. The MAX22256B/C are optimized for LLC-type resonant topology, improving efficiency, and reducing switching noise.
The MAX22256/MAX22258 family features a resistor-adjustable current limit that allows indirect limiting of the secondary-side load current and protects the primary power source in the event of secondary- or field-side failure.
The MAX22256/MAX22258 i..
²é¿´È«ÎÄ
  • ·ÖÏíµ½£º
²ÂÄãϲ»¶
