¹Ø¼ü´Ê£ºÒÔÌ«Íø 10BASE£T1L PHY ¹¤³§×Ô¶¯»¯ Â¥Óî×Ô¶¯»¯ ADI ADIN2111
ʱ¼ä£º2022-04-26 14:25:19 À´Ô´£ºÖеçÍø
ADI¹«Ë¾µÄADIN2111Êǵ͹¦ºÄµÍ¸´ÔÓ¶ÈË«ÒÔÌ«Íø¶Ë¿Ú½»»»»ú, ¼¯³ÉÁË10BASE-T1L PHYºÍÒ»¸ö´®ÐÐÍâÉè½Ó¿Ú(SPI)¶Ë¿Ú. ¸ÃÆ÷¼þʹÓõ͹¦ÂÊÊÜÏÞ½Úµã,ÃæÏò¹¤ÒµÒÔÌ«ÍøÓ¦ÓÃÇÒ·ûºÏIEEE® 802.3cg-2019™ÒÔÌ«Íø±ê×¼,ÊÊÓÃÓÚ³¤¾àÀë10 Mbpsµ¥¶ÔÒÔÌ«Íø(SPE). ADIN2111Ö§³Ö¸ß´ï1700Ã׵ĵçÀÂÑÓÉ췶Χ,¾ßÓÐ77 mWµÄ³¬µÍ¹¦ºÄ.Á½¸öPHYÄÚºËÖ§³ÖIEEE 802.3cg±ê×¼Öж¨ÒåµÄ1.0 V p-p¹¤×÷ģʽºÍ2.4 V p-p¹¤×÷ģʽ,¿É²ÉÓÃ1.8 V»ò3.3 Vµ¥µçÔ´¹ì¹©µç. ADIN2111¿ÉÓÃÓÚ·ÇÍйÜÅäÖÃ,ÔÚ´ËÅäÖÃÏÂ,Æ÷¼þ¿É×Ô¶¯×ª·¢Á½¸öÒÔÌ«Íø¶Ë¿ÚÖ®¼äµÄÁ÷Á¿.¸ÃÆ÷¼þ¼¯³ÉÁ˽»»»»ú,Á½¸ö¾ßÓнéÖÊ·ÃÎÊ¿ØÖÆ(MAC)½Ó¿ÚµÄÒÔÌ«ÍøÎïÀí²ã(PHY)ÄÚºËÒÔ¼°ËùÓÐÏà¹ØµÄÄ£Äâµç·,ÊäÈëºÍÊä³öʱÖÓ»º³åÆ÷¼þ.¸ÃÆ÷¼þ»¹°üÀ¨ÄÚ²¿»º³å¶ÓÁÐ,SPIºÍ×Óϵͳ¼Ä´æÆ÷,ÒÔ¼°ÓÃÀ´¹ÜÀí¸´Î»ºÍʱÖÓ¿ØÖƼ°Ó²¼þÒý½ÅÅäÖõĿØÖÆÂß¼.Æ÷¼þ²ÉÓÃ48 Òý½Å 7 mm ¡Á 7 mm LFCSP·â×°,¹¤ÒµÎ¶È−40¡ãC ÖÁ +85¡ãC,À©Õ¹Î¶ÈΪ−40¡ãC ÖÁ +105¡ãC.Ö÷ÒªÓÃÔÚÂ¥Óî×Ô¶¯»¯ºÍÏû·À°²È«,¹¤³§×Ô¶¯»¯,±ßÔµ´«¸ÐÆ÷ºÍÖ´ÐÐÆ÷ºÍ״̬¼à¿ØºÍ»úÆ÷Á¬½Ó.±¾ÎĽéÉÜÁËADIN2111Ö÷ÒªÌØÐÔ,¹¦ÄÜ¿òͼºÍÓ¦Óõç·,ÒÔ¼°ÆÀ¹À°åEVAL-ADIN2111EBZÖ÷ÒªÌØÐÔ,¿òͼ,µç·ͼ,²ÄÁÏÇåµ¥ºÍPCBÉè¼ÆÍ¼.
The ADIN2111 is a low power, low complexity, two-Ethernet ports switch with integrated 10BASE-T1L PHYs and one serial peripheral interface (SPI) port. The device is designed for industrial Ethernet applications using low power constrained nodes and is compliant
with the IEEE® 802.3cg-2019™ Ethernet standard for long reach 10 Mbps single pair Ethernet (SPE). The switch (cut through or store and forward) supports various routing configurations between the two Ethernet ports and the SPI host port providing a fl..
·ÖÏíµ½£º
²ÂÄãϲ»¶
