[原创]Microchip INT01156电动滑板车BLDC马达驱动参考设计
关键词:马达驱动 BLDC/PMSM 电动滑板车 Microchip INT01156
时间:2022-04-18 14:02:37       来源:中电网
Microchip公司的INT01156是高性能电动滑板车BLDC马达驱动器参考设计,能够驱动高达350W和15A  RMS相电流的BLDC/PMSM马达.输入电压范围在18V和42V之间,包括多达10颗锂电池串.高性能BLDC/PMSM马达驱动器板采用dsPIC33CK高性能数字信号控制器(DSC)和MIC4104 (MOSFET栅极驱动器),用来马达控制应用如电动滑板车和电动自行车.驱动板满足了现代马达控制应用的高效率,紧凑尺寸,低成本和高性能.最大输出功率350W,马达连续相电流15A RMS,短时间马达相电流高达27A RMS.每个逆变器相的低边并联电阻用于电流测量(2 mΩ).PWM开关频率从8 kHz到50 kHz(典型为20kHz).驱动板有六个N沟MOSFET,RDS(on)典型值为1.9 mΩ.支持传感器/无传感器马达控制算法.本文介绍了参考设计INT01156主要特性, 框图,电路图,材料清单和PCB设计图.
The High-Performance E-Scooter BLDC Motor Driver Reference Design targets high-performance, cost-effective motor control applications: for example, applications for low-power E-mobility solutions (E-scooters, E-bikes, etc.). The High-Performance E-Scooter BLDC Motor Driver Reference Design is able to drive BLDC/PMSM motors of up to 350W power and up to 15A RMS phase currents. The input voltage range is between 18V and 42V covering the applications powered from battery strings of up to 10S (Li-Ion cells).
查看全文
