Öйúµç×Ó¼¼ÊõÍø
ÉèΪÊ×Ò³ ÍøÕ¾µØÍ¼ ¼ÓÈëÊÕ²Ø
[Ô­´´]Renesas RA6M5¸ßÐÔÄÜ200MHz ARM MCU¿ª·¢·½°¸
¹Ø¼ü´Ê£ºArm Cortex£­M33 MCU Renesas RA6M5
ʱ¼ä£º2021-09-28 16:44:56       À´Ô´£ºÖеçÍø
Renesas¹«Ë¾µÄRA6M5ÊǸßÐÔÄÜ200MHz »ùÓÚArm® Cortex®-M33 Äں˵Ä΢¿ØÖÆÆ÷,¼¯³ÉÁ˶à´ï2MB´úÂëÉÁ´æ,8KBÊý¾ÝÉÁ´æºÍ´ø¼«ÐÔ/ECCµÄ512KB SRAM.¸ß¶È¼¯³ÉµÄÒÔÌ«ÍøMAC¿ØÖÆÆ÷,¿ÉÈ·±£¸ßÊý¾ÝÍÌÍÂÂÊ,USB 2.0¸ßËÙ,CAN FD,SDHI,QuadºÍOcta SPIÒÔ¼°ÏȽøµÄÄ£Äâµç·.»¹¼¯³ÉÁ˰²È«¼ÓÃÜÒýÇæºÍ¼ÓÃܼÓËÙÆ÷,Ö§³ÖÃÜÔ¿¹ÜÀí¼¼Êõ,´Û¸Ä¼ì²âºÍ¹¦ÂÊ·ÖÎöµç×è,Ö§³ÖTrustZone®.ÓëÆ¬Äڵݲȫ¼ÓÃÜÒýÇæ(SCE)ÅäºÏʹÓÃ,¿ÉʵÏÖ°²È«Ð¾Æ¬µÄ¹¦ÄÜ.RA6M5 ²ÉÓøßЧµÄ 40nm ¹¤ÒÕ,¿ÉÒÔÂú×ãÎïÁªÍøÓ¦ÓõÄÐèÇóÈçÒÔÌ«Íø,ÃæÏòδÀ´Ó¦Óõݲȫ¹¦ÄÜ,´óÈÝÁ¿Ç¶Èëʽ RAM ºÍµÍ¹¦ºÄCoreMark® Ëã·¨,µÍÖÁ 107uA/MHz.Ö÷ÒªÓÃÔÚÓÐÏßÒÔÌ«ÍøÓ¦ÓÃ,ÐèÒªÔöÇ¿°²È«¹¦ÄܵIJúÆ·Èç»ðÔÖ̽²â,·ÀµÁ¼ì²âºÍÃæ°å¿ØÖÆ,±í¼ÆÀà²úÆ·ÈçµçÁ¦ºÍ×Ô¶¯³­±í,ÒÔ¼°¹¤ÒµÓ¦ÓÃÈç»úÆ÷ÈË,¿ªÃÅÆ÷,·ìÈÒ»ú,×Ô¶¯ÊÛ»õ»úºÍUPS,HVACºÍÒ»°ãÓÃ;.±¾ÎĽéÉÜÁËRA6M5Ö÷ÒªÌØÐÔ,¿òͼºÍRA6M5 MCU Ⱥ×éÆÀ¹ÀÌ×¼þÖ÷ÒªÌØÐÔ,¿òͼ,µç·ͼ,²ÄÁÏÇåµ¥ºÍPCBÉè¼ÆÍ¼.
High-performance 200 MHz Arm Cortex-M33 core, up to 2 MB code flash memory with Dual-bank, background and SWAPoperation, 8 KB Data flash memory, and 512 KB SRAM with Parity/ECC. High-integration with Ethernet MAC controller, USB2.0 High-Speed, CAN FD, SDHI, Quad and Octa SPI, and advanced analog.Integrated Secure Crypto Engine withcryptography accelerators, key management support, tamper detection and power analysis resistance in concert with ArmTrustZone for integrated secure element functionality.
The MCU integrates multiple series of software- and pin-compatible Arm®-based 32-bit cores that share a common set ofRenesas peripherals to facilitate desi..
²é¿´È«ÎÄ
  • ·ÖÏíµ½£º
²ÂÄãϲ»¶
