Öйúµç×Ó¼¼ÊõÍø
ÉèΪÊ×Ò³ ÍøÕ¾µØÍ¼ ¼ÓÈëÊÕ²Ø
[Ô­´´]Infineon ICL88xxϵÁÐ43W·´¼¤×ª»»Æ÷²Î¿¼Éè¼Æ
¹Ø¼ü´Ê£ºµçÔ´¹ÜÀí LEDÇý¶¯Æ÷ AC£¯DCת»»Æ÷ Infineon ICL88xx
ʱ¼ä£º2021-08-27 13:32:35       À´Ô´£ºÖеçÍø
Infineon¹«Ë¾µÄICL8800, ICL8810ºÍICL8820Êǵçѹģʽ¿ØÖÆÆ÷,ÓÃÓÚ¹¤×÷ÔÚ׼гÕñģʽºÍ²¨¹È¿ª¹ØDCMµÄ·´¼¤ÍØÆË.Éè¼ÆÓÃÓÚÐèÒª¸ß¹¦ÂÊÒòËÙºÍЧÂʵĵͺ͸߹¦ÂÊÁ÷Ã÷оLEDÇý¶¯Æ÷,·´¼¤¿ØÖÆÆ÷Äܹ»¿ØÖÆSSR-CVºÍPSR-CVÍØÆË.Ôڵͳɱ¾Ó¦ÓÃ,Á½¼¶ÍØÆËµÄPFC¹¦ÄÜÊÇÐèÒªµÄ.¶ÔÓÚÕÕÃ÷Ó¦ÓÃ,¼¯³Éµç·Ìṩ¿íµÄ¹¤×÷µçѹºÍÍêÕûµÄ±£»¤,°üÀ¨¹¦ÂÊÏÞÖÆ.Æ÷¼þÈݵÃÉè¼ÆºÍÐèÒª×îµÍÊýÁ¿µÄÍâ½ÓÔª¼þ.Õ¤¼«Çý¶¯Æ÷µçÁ÷¾ßÓÐʹÓÃ×îÏȽø¼¼ÊõµÄMOSFET,¸ß´ï125W.ϵͳÐÔÄܺÍЧÂÊ.ÌØ±ðÊÇÇá¸ºÔØÌõ¼þÏÂ,²ÉÓÃInfineon¹«Ë¾µÄCoolMOS™ P7¹¦ÂÊMOSFETÄܽøÐÐÓÅ»¯.Æ÷¼þÖ§³ÖͨÓÃÊäÈëµçѹ(90 VAC µ½300 VAC, 45 Hzµ½ 66 Hz)ºÍDCÊäÈëµçѹ.ÔÚ¿í¸ºÔØºÍÊäÈëACÏß·µçѹ·¶Î§¾ßÓи߹¦ÂÊÒòËÙµÍTHDÐÔÄÜ.Æ÷¼þµÄÍêÕû±£»¤¹¦ÄܰüÀ¨ÄÚ²¿³¬Î±£»¤(OTP),Êä³ö¹ýѹ±£¹ÜÔ±(OVP),¹ýÁ÷±£»¤(OCP),»ºÉýºÍµÍÂä±£»¤,ÒÔ¼°¿ªÂ·±£»¤ºÍÊäÈë¹ýѹ±£»¤.ÆäÖеÄÈíÆð¶¯ÄܽµµÍ¿ª¹ØÊ±µÄÓ¦Á¦.Ö÷ÒªÓÃÔÚLEDÇý¶¯Æ÷ºÍ¸ß´ï125WÕÕÃ÷ÒÔ¼°¸ß´ï125WµÄÊÊÅäÆ÷,³äµçÆ÷,ƽ°åTV<È«ºÏÒ»PCºÍ¼àÊÓÆ÷.±¾ÎĽéÉÜÁËICL8800, ICL8810ºÍICL8820ͨÓÃÌØÐÔ,ÒÔ¼°ICL8810, ICL8820ÆäËüÌØÐÔ,·´¼¤SSR-CV¿òͼºÍ·´¼¤PSR-CV¿òͼ,Æ÷¼þ¿òͼÒÔ¼°43W²Î¿¼Éè¼ÆREF_ICL8810_LED_43W_BMÖ÷ÒªÌØÐÔºÍÖ¸±ê,µç·ͼ,²ÄÁÏÇåµ¥ºÍPCB²¼¾Öͼ.
The ICL8800, ICL8810 and ICL8820 is a voltage mode controller for flyback topologies operating in quasiresonantmode and valley switching DCM. It is designed for low and high power lumen LED driver, requiringhigh power factor and efficiency. The flyback controller is capable of controlling SSR-CV an PSR-CV topologies.
Offering a wide usage in low cost applications where a PFC functionality in dual stage topologies is required.For lighting applications, the IC offers a wide power range as well as a comprehensive set o..
²é¿´È«ÎÄ
  • ·ÖÏíµ½£º
²ÂÄãϲ»¶
