¹Ø¼ü´Ê£ºÆû³µµç×Ó LED Maxim MAX25606
ʱ¼ä£º2021-08-11 13:26:50 À´Ô´£ºÖеçÍø
Maxim¹«Ë¾µÄMAX25606ÊÇÆû³µÕÕÃ÷ÓÃÁù¿ª¹ØÕóÁйÜÀí¼¯³Éµç·,¾ßÓÐÁù¸öµ¥¶À¿ØÖƵÄN¹µMOSFET¿ª¹Ø,ÿ¸ö¿ª¹ØµÄ¿ªÌ¬µç×è0.2¦¸,¶î¶¨µçѹ16V.µ¥µçÁ÷Ô´ÄÜÓÃÀ´¸øËùÓд®ÁªµÄLED¹©µç.µ¥¸öLEDͨ¹ý¿ç½ÓµÄÅÔ·¿ª¹Ø¿ªÍ¨ºÍ¹Ø¶ÏÀ´½øÐе÷¹â.Æ÷¼þ¿ÉÅäÖóÉÁ½¸ö´®ÐÐÓ¦ÓÃ:ÿ´®Èý¸ö¹Ø´®Áª.ÿ¸ö¿ª¹ØÄÜ´®ÐÐÁ¬½ÓÒ»¸ö,Á½¸ö»òÈý¸öLED.Æ÷¼þ»¹¿ªÒÔ²¢ÁªÁ½¸ö¿ª¹Ø,´óµçÁ÷LED¹©µç.Æ÷¼þ»¹°üÀ¨ÄÚ²¿µçºÉ±Ã,¸øLEDÅÔ·¿ª¹ØµÄÕ¤¼«Çý¶¯Æ÷ÌṩµçÔ´.Æ÷¼þ¾ßÓжà֧·UARTͨÐżÈÈ»¿Ú,¶à´ï64¸ö¿ÉѰַµÄÆ÷¼þ,ºÍCANÎïÀí²ã¼æÈÝ,ÓÅ»¯µÄPWMµ÷¹âÌṩ¼«ºÃµÄµ÷¹âÐÔÄÜ,¿É±à³ÌµÄ12λPWMµ÷¹â,PWMµ÷¹â״̬½¥±ä¹ý¶É,ÄÚ²¿Ê±ÖÓ·¢ÉúÆ÷»òÍâ½ÓʱÖÓÓÃÀ´µ÷¹â,¿É±à³ÌµÄת»»ËÙÂÊÓÃÓÚEMI¿ØÖÆ.Æ÷¼þÂú×ãAEC-Q100 grade 1¹æ·¶,¹¤×÷ζÈ-40C µ½ +125C.Ö÷ÒªÓÃÔÚÆû³µÕóÁÐLEDϵͳºÍ×ÔÊÊÓ¦Ô¶¹âµÆ.±¾ÎĽéÉÜÁËMAX25606Ö÷ÒªÓÅÊÆºÍÌØÐÔ,¼ò»¯¿òͼºÍ¿òͼ,6·ÕóÁÐÕÕÃ÷µç·ÒÔ¼°ÆÀ¹ÀϵͳMAX25606 EVSÖ÷ÒªÌØÐÔ,µç·ͼ,²ÄÁÏÇåµ¥ºÍPCBÉè¼ÆÍ¼.
The MAX25606 6-switch matrix manager IC for automotive lighting applications includes a 6-switch array for bypassing individual LEDs in a single- or dual-string application. It features six individually controlled n-channel MOSFET switches with each switch having an on-resistance of 0.2¦¸ and rated to withstand 16V. A single current source can be used to power all the LEDs connected in series. Individual LEDs can be dimmed by turning on and off the bypass switches across each LED. The device can also be configured in two string applications with three switches in series per string. Each switch can be connected across one, two, or three LEDs in series. It also allows for parallel connec..
·ÖÏíµ½£º
²ÂÄãϲ»¶
