[原创]RenesasRA6M1 120MHz ARM MCU开发方案
关键词:Arm® Cortex®-M4 MCU
时间:2021-05-20 15:00:37       来源:中电网
Renesas公司的RA6M1是120MHzArm® Cortex®-M4核 MCU,集成了512KB代码闪存,256KB SRAM,容性触摸检测单元,USB 2.0全素,SDHI,Quad SPI,防护与安全特性和先进的模拟.MCU集成了软件和引脚兼容的基于Arm®32位核的多个系列,共享Renesas外设共同集,方便了设计的升级和基于平台的有效的产品开发.器件还集成了12位ADC,12位DAC和模拟外设.防护与安全特性包括了AES128/192/256,3DES/ARC4, SHA1/SHA224/SHA256/MD5, GHASH,RSA/DSA/ECC以及随机号码发生器(TRNG).工作电压2.7V到3.6V,工作温度-40°C到+85°C.主要用在物联网应用以及安全装置(火灾探测,防盗检测,面板控制),表计类产品(电力,自动抄表),工业应用(机器人,开门器,缝纫机,自动售货机,UPS),健康管理和可穿戴人体传感器与智能家居和遥控玩具.本文介绍了RA6M1主要特性,框图以及评估板EK-RA6M1 v1主要特性,系统框图,电路图,材料清单和PCB设计图.
Leading performance 120-MHz Arm® Cortex®-M4 core, 512-KB code flash memory, 256-KB SRAM, CapacitiveTouch Sensing Unit, USB 2.0 Full-Speed, SDHI, Quad SPI, security and safety features, and advanced analog.
The MCU integrates multiple series of software- and pin-compatible Arm®-based 32-bit cores that share a common setof Renesas peripherals to facilitate design scalability and efficient platform-based product development.
The MCU in this series incorporates a high-performance Arm Cortex®-M4 core running up to 120 MHz with thefollowing features:
查看全文
