[原创]Infineon XDPS2201混合反激控制器解决方案
关键词:电源管理 开关电源 AC/DC转换器 超高效率开关电源(SMPS) Infineon XDPS2201
时间:2021-05-18 16:49:45       来源:中电网
Infineon公司的XDPS2201是基于非对称半桥控制的XDP混合反激控制器.半桥驱动和串联电容连接的反激变压器.反激变压器的主要电感和串联电容形成谐振回路,可以得到半桥功率开关的零电压开关(ZVS)特性,在反激变器的通常去磁相中提供另外的谐振功率发送.数字混合反激控制器在DSO-14(150密尔)封装中集成了半桥驱动器,600V高压起动单元可用于快速充电和低待机功耗,而峰值电流模式控制用于强健和快速线路与负于控制,突发模式基于输出电流估计值进入/退出操作,初级边输出过压保护,支持最低无负载待机功耗小于75mW,可配置的缓升和低落保护,内置软起动,以及可配置小滞后的突发模式进入和退出,可配置过流保护和输出过压保护,可配置开关频率抖动,可配置传输延迟补偿以精确峰值电流控制,可配置跳周期的降频以改善低负载效率.主要用在案AC/DC SMPS,大于20W/inch³的超高功率密度的适配器,以及大于93%的超高效率的开关电源.本文介绍了XDPS2201产品亮点和主要特性,框图和应用电路图,以及65W高功率密度快速充电板主要特性和指标,电路图,材料清单和PCB设计图.
The XDPS2201 contains a Hybrid-flyback controller that is based on an asymmetrical half-bridge control. Thehalf-bridge is driving a conventional flyback transformer in conjunction with a serial capacitor. The maininductance of the flyback transformer and the serial capacitor are building a resonant tank, which is used forachieving zero voltage switching (ZVS) behavior of the half-bridge power switches and is providing in additiona resonant power transmission during the conventional demagnetization phase of the flyback transformer.
During normal operation the charge period and associated power is controlled by direct peak current control,whereas the demagnetization..
查看全文
