[原创]Infineon IPN60R2K0PFD7S+2ED28073J06F 100W马达驱动方案
关键词:工业应用 马达驱动 Infineon
时间:2021-04-09 16:39:00       来源:中电网
Infineon公司的EVAL_FAN_XMC_PFD7是100W马达驱动评估板,主要包括600V CoolMOS PFD7 SJ功率器件IPN60R2K0PFD7S和600V 高压高速功率MOSFET和IGBT驱动器.此外还包括基于ARM® Cortex®-M0的XMC1302-T038X0200 32位MCU,准谐振CoolSET™反激控制器ICE5QR4770AG,低压降电压稳压器IFX1763XEJV50以及P沟MOSFET BSS314PE和N沟MOSFET BSS138N.评估板EVAL_FAN_XMC_PFD7采用AC输入电压,最大输出功率为100W,能驱动FOC无传感器模式的三相BLDC/PMSM马达,适合风扇和泵的应用.本文介绍了IPN60R2K0PFD7S主要特性和优势,2ED28073J06F主要特性和框图,以及100W马达驱动评估板EVAL_FAN_XMC_PFD7主要特性,指标和主要元件,电路图,材料清单和PCB设计图.
This application note provides an overview of the evaluation board EVAL_FAN_XMC_PFD7, including its main features, key data, pin assignments, schematics and layout. It also describes how to quickly get started with this demo PCB and take advantage of Infineons CoolMOS™ PFD7 superjunction MOSFETs, CoolSET™ quasi-resonant (QR) flyback controller and XMC1000 series microcontroller. A step-by-step getting started guide can be found here.
查看全文
