关键词:Arm Cortex-M7 MCU 马达控制 家用电器 工业人机接口(HMI) NXP
时间:2021-03-22 16:29:31 来源:中电网
NXP公司的i.MX RT1060是基于Arm Cortex®-M7核的消费类电子交叉处理器,工作速率高达600MHz,提供高CPU性能和最好的实时响应.该处理器具有1MB片上RAM,其中的512KB可灵活配置成TCM或通用片上RAM,而其它的512KB是通用片上RAM.i.MX RT1060集成了先进功率管理模块和DC/DC转换器和LDO,降低了复杂外接电源,简化了加电次序.器件还提供了各种存储器接口,包括SDRAM, RAW NAND FLASH, NORFLASH, SD/eMMC, Quad SPI和各种其它用于连接外设的接口如WLAN, 蓝牙™, GPS, 显示器和照相机传感器.i.MX RT1060还有丰富的音频和视频特性,包括LCD显示,基本2D图像,照相机接口,SPDIF和I2S音频接口,以及模拟接口如ADC,ACMP和TSC.主要用在马达控制,家用电器和工业人机接口(HMI).本文介绍了i.MX RT1060主要特性,系统框图,评估板MIMXRT1060-EVK主要特性,电路图和材料清单.
The i.MX RT1060 is a new processor family featuringNXPs advanced implementation of the ArmCortex®-M7 core, which operates at speeds up to 600MHz to provide high CPU performance and bestreal-time response.
The i.MX RT1060 processor has 1 MB on-chip RAM.512 KB can be flexibly configured as TCM or generalpurpose on-chip RAM, while the other 512 KB isgeneral-purpose on-chip RAM. The i.MX RT1060integrates advanced power management module withDCDC and LDO that reduces complexity of externalpower supply and simplifies power sequencing. Thei.MX RT1060 also provides various memory interfaces,including SDRAM, RAW NAND FLASH, NORFLASH, SD/eMMC, Quad SPI, and a wide range ofother interfaces for..
分享到:
